Nikkor Ai-P 45mm f/2.8 - Review / Lab Test Report
Review by Klaus Schroiff, published January 2007
Lens kindly provided for testing purposes by Peter-Cornelius Spaeth!
There aren´t really many lenses left out there which could really excite me but the Nikkor Ai-P 45mm f/2.8 qualifies here. The Pentax folks have lots of ´em whereas there´s only one (recent) Nikkor and no Canon EF equivalent at all in this category - it is a so-called pancake lens. The meaning gets pretty obvious when looking at the lens: it is flat with a "length" of a mere 17mm ... and it is sweet. 8-)
The story behind this lens is pretty interesting because the design is about as old as photography itself - it is a Tessar and the sound of it already indicates its origins: Carl-Zeiss. Since its invention in 1902 by Dr. Paul Rudolph more than 100mio. (!) of these lenses were manufactured (source: Wikipedia). At the time the idea was simple and efficient - minimize the number of elements to reduce flare and to increase contrast and center resolution - lens coatings did not exist till much, much later in the century. Tessars are limited to relatively slow speeds which is why most manufacturers replaced it by faster but also more complex designs later on. However, the idea never really went extinct so you can still find a few Tessar-variants here and there.
In late 2001 Nikon released its latest interpretation of the story - the Ai-P 45mm f/2.8. It is a manual focus lens but thanks to a CPU it is compatible with all exposure modes of CPU-controlled Nikon (D)SLRs. The lens has a dedicated aperture ring but on modern DSLRs you have to set the lens to automatic aperture so it behaves like a "G" lens here. Initially the lens was meant as a kit lens for the Nikon FM3A but it was also available separately. "Was" because unfortunately Nikon decided to discontinue the lens recently but you may still find it in shops here and there if you´re lucky. Naturally cuteness itself is no application for a lens and f/2.8 is slow by today´s normal lens standards - probably a reason why this Nikkor didn´t find many new friends except collectors and photographers seeking for a super-compact setup (outdoor, street photography). The D200 as shown above is probably no perfect match for this lens but something like a D40 would be able to compete with some of the bigger digicams size-wise. Here´s a visual comparison between the Ai-P 45mm f/2.8, AF 50mm f/1.8D and the new Zeiss ZF 50mm f/1.4.
Thanks to a full-metal construction is the build quality is excellent. The tiny focus ring operates smooth and it is well-damped like in the good ´ol times. As you can see in the product shots it extends/retracts slightly when changing focus. The front element does not rotate so using a polarizer is no problem. A micro-hood is also part of the package.
Equiv. focal length67.5 mm (full format equivalent)
Optical construction4 elements in 3 groups
min. focus distance0.45 m (max. magnification ratio 1:7.6)
Dimensions62 x 17 mm
Weight120 g
Filter size52 mm (non-rotating)
HoodNikon HN-35 (included), barrel shaped (screw-in)
Other featuresmanual focus only. Compatible to all Nikon DSLRs thanks to CPU.
