Tamron AF 18-250mm f/3.5-6.3 Di II LD Aspherical [IF] macro (Nikon) - Review / Lab Test Report
Review by Klaus Schroiff, published June 2007
Lens kindly provided by Tamron Europe!
Back in the 1992 Tamron started the extreme or "super" zoom era with the release of the the AF 28-200mm F/3.8-5.6 Aspherical, a 7.1x zoom ratio lens. At the time it was quite a sensation whereas today such lenses have found their way into the heart of the mainstream. Tamron released various new incarnations over time including the 28-300mm (10.7x) and the first dedicated APS-C super-zoom - the 18-200mm XR (11.1x) - and this year they pushed it even further with the new Tamron AF 18-250mm f/3.5-6.3 Di II LD Aspherical [IF] macro breaking the existing zoom ratio record again (13.9x) - the zoom range translates a field-of-view equivalent to a 27-375mm (full format). Normally you would expect such a beast to be fairly massive but Tamron is also renowned for lens miniaturization and the 18-250mm isn't any bigger than a typical mid-range zoom. One of the reasons for this is surely the very slow max. aperture of f/6.3 @ 250mm. This is a bit of a borderline approach because most AF system are only specified till f/5.6 (officially) and you need quite a bit of light (or high ISO) to use this lens hand-held.
In terms of build quality the Tamron is a fairly typical consumer grade zoom lens. Most of the outer construction is made of plastic except for the metal mount (which is an upgrade compared to the old 18-200mm XR). The broad rubberized zoom ring has a varying friction and it wobbles a little whereas the small focus ring operates reasonably smooth although somewhat "scratchy". The lens uses a duo-cam zoom mechanism (two inner lens tubes) to extend towards to long end of the zoom range. At 250mm the lens is about twice as long as full retracted (@ 18mm). Surprisingly the duo-cams showed no tendency to wobble despite the extreme extension. The tested sample did not suffer from zoom creeping (which may develop over time) but Tamron implemented a transport lock (18mm only) just in case.
Note: The product image above shows the Canon variant of the lens
The lens has no internal AF motor and relies on a slotted drive screw operated by the camera. This generates some noise during AF operations and the AF speed is comparatively slow although reasonably accurate on the D200.
Equiv. focal length27-375 mm (full format equivalent)
Equiv. aperturef/5.3-f/9.5 (full format equivalent, in terms of depth-of-field)
Optical construction16 elements in 13 groups inc. 1x AD, 2x LD and 2x hybrid aspherical elements
Number of aperture blades7
min. focus distance0.45 m (max. magnification ratio ~1:3.5)
Dimensions84 x 83 mm
Weight430 g
Filter size62 mm (non-rotating)
Hoodsupplied, petal-shaped, snap-on type
