Sony 135mm f/2.8 [T4.5] STF ( SAL-135F28 ) - Review / Test Report
Review by Klaus Schroiff, published August 2008
Special thanks to Konrad Kandler for providing this lens for testing purposes!
The Sony 135mm f/2.8 [T/4.5] STF is a unique lens in many ways. The most obvious difference compared to conventional lenses is the lack of AF. So why's that ? The lens has a so-called apodisation optics using one APD element. APD elements resemble neutral density filters which become thicker the more you move towards the perimeter thus reducing the amount of light passing through. Out-of-focus circles are therefore (comparatively) defined in the center but are gradually loosing light towards the edges thus producing a very silky bokeh (out-of-focus blur) - the primary sense of existence of this lens.
This special characteristic has a side-effect though - the "smooth transitions focus" (STF) effect is hostile for AF operations and consequently the focus indicator in the viewfinder remains also non-functional. Obviously an aspect which may produce headaches for some users.
Another consequence of the APD elements is a decreased light transmission characteristic (the mentioned ND effect) - you lose about 1 1/2 f-stops (actually 1.5 f-stops) thus the [T/4.5] in the lens' name. The T-value does not change the principal speed (min. depth-of-field) of the lens (=max f/2.8) but you will only see the T-value in the viewfinder.
The design of the lens dates back to the late Minolta era so it is obviously a full format lens - on APS-C DSLRs its field-of-view is equivalent to about 203mm.
The build quality of the Sony lens is superb thanks to a metal construction and tight tolerances. The focus ring operates very smoothly and damped just like in the good ol' days.
Unlike typical Sony Alpha lenses the STF has a dedicated aperture control ring which allows you to set the aperture steplessly between T/4.5 and T/6.7 - this controls a secondary aperture with 10 aperture blades. When selecting the "A" position the primary aperture (9 aperture blades) is controlled by the camera.
You may notice in the product images below the lens extends significantly when focusing towards close distances. The front element does not rotate.
If you are interested in further details you may have a look at the following website
Equiv. focal length202.5 mm (full format equivalent)
Optical construction8 elements in 6 groups inc. 1x APD element
Number of aperture blades10 (in stepless aperture mode), 9 (in automatic aperture mode), circular
min. focus distance0.87 m (max. magnification ratio 1:4)
Dimensions80 x 99 mm
Weight730 g
Filter size72 mm (non-rotating)
Hoodbarrel-shaped, snap-on-type, supplied
Other featuresSTF
