Canon EF-S 17-85mm f/4-5.6 USM IS - Review / Test Report - Sample Images & Verdict
Ok, finally here're some sample shots taken with the EOS 350D. These JPEGs were RAW-converted via RSE which auto-corrects most chromatic aberrations.
Make Canon
Model Canon EOS 350D DIGITAL
Focal Length 53.0mm
Exposure Data: f/10.0 @ 1/60s
Size 3472x2312
Make Canon
ISO Speed 400
Focal Length 85.0mm
Exposure Data: f/9.0 @ 1/125s
Size 3472x2312
Make Canon
Focal Length 85.0mm
Exposure Data: f/8.0 @ 1/160s
Size 3472x2312
Make Canon
Focal Length 44.0mm
Exposure Data: f/11.0 @ 1/50s
Size 2312x3472
Make Canon
ISO Speed 400
Focal Length 85.0mm
Exposure Data: f/8.0 @ 1/500s
Size 3472x2312
Make Canon
ISO Speed 100
Focal Length 50.0mm
Exposure Data: f/9.0 @ 1/640s
Size 2312x3472
Make
ISO Speed 100
Focal Length 38.0mm
Exposure Data: f/9.0 @ 1/400s
Size 2312x3472
The EF-S 17-85mm f/4-5.6 USM IS is a lens that promises many things. It is certainly a very versatile standard zoom with a long zoom range and an image stabilizer that can save the day in many situations. However, the build quality is somewhat disappointing and optically it is also something of a mixed bag. The lens is very sharp in the image center throughout the range but at the wide-end the extreme corners leave something to be desired. The 17mm setting also suffers from rather extreme distortions and rather hefty vignetting @ f/4. Finally chromatic aberrations aren't really something to rave about either.
So at the end of the day the lens is a tad better than the cheapo EF-S 18-55mm f/3.5-5.6 but it can't really compete with the new EF-S 18-55m f/3.5-5.6 IS or the EF 17-40mm f/4 USM L. The key feature of the EF-S 17-85mm f/4-5.6 USM IS remains its versatility. While this may sound a little sceptical I should note that I preferred the lens compared to other higher quality options during testing - it is simply a darn convenient lens and despite the flaws it can produce very decent images as you can see from the samples - at least with a little tool support.
