Sigma AF 180mm f/3.5 EX HSM APO macro - Review / Test Report - Analysis
As to be expected from a fix-focal lens and especially for a macro lens the level of distortion is absolutely negligible.
On the EOS 350D with its reduced format (APS-C) the (full format) lens exhibits very little vignetting at f/3.5. From f/5.6 & up the issue is pretty much negligible. There's marginally less vignetting at 1:1 macro setting compared to infinity focus.
Macro lenses tend to be sweet performers regarding resolution and that's also true for the AF 180mm f/3.5 EX APO macro. At f/3.5 the resolution figures are already very-good increasing further to medium aperture settings where the quality scratches the resolution limits of the 350D's 8MP sensor. Beyond f/8 diffraction is the limiting factor but the resolution is still very decent at f/16 and usable at f/22. The lens provides a f/32 setting but it should be generally avoided due to the rather soft image quality here (a normal behaviour).
It came by surprise but CAs (color shadows at harsh contrast transitions) are a very weak spot of the lens. At large aperture settings the issue is quite well controlled but from f/8 & up the level of CAs is quite extreme peaking beyond 1.5 pixels at the image borders. This behaviour is quite unusual for a fix-focal lens. The CAs had a very even distribution in the tested sample so correcting the issue via an imaging tool shouldn't be a big deal but the lens performed a little disappointing here nonetheless.
