Tamron SP 15-30mm f/2.8 Di VC USD G2 - Review / Test Report - Sample Images & Verdict
MakeCanon
ModelCanon EOS 5DS R
ISO Speed200
Focal Length30.0mm
Aperture:f/9.0
Exposure1/320s
MakeCanon
ISO Speed200
Focal Length15.0mm
Aperture:f/9.0
Exposure1/320s
MakeCanon
ISO Speed100
Focal Length23.0mm
Aperture:f/2.8
Exposure1/8000s
MakeCanon
ISO Speed100
Focal Length30.0mm
Aperture:f/11.0
Exposure1/100s
MakeCanon
ISO Speed100
Focal Length15.0mm
Aperture:f/2.8
Exposure1/3200s
MakeCanon
ISO Speed100
Focal Length15.0mm
Aperture:f/11.0
Exposure1/250s
MakeCanon
ISO Speed100
Focal Length15.0mm
Aperture:f/10.0
Exposure1/250s
MakeCanon
ISO Speed100
Focal Length15.0mm
Aperture:f/10.0
Exposure1/160s
MakeCanon
ISO Speed100
Focal Length15.0mm
Aperture:f/10.0
Exposure1/125s
MakeCanon
ISO Speed100
Focal Length15.0mm
Aperture:f/11.0
Exposure1/100s
MakeCanon
ISO Speed100
Focal Length30.0mm
Aperture:f/2.8
Exposure1/1000s
As already hinted, the primary competitor of the Tamron SP 15-30mm f/2.8 Di VC USD G2 (shown to the left below) is the Canon EF 16-35mm f/2.8 USM L III (to the right). Sharpness-wise there isn't too much between the two. The Canon lens is, however, better in terms of flare and it shows fewer CAs. At f/2.8 it vignettes like hell though. It's also much more light-weight. Another lens to consider is the Sigma 14-24mm f/2.8 DG HSM ART. The Tamron is a tad sharper specifically at 24mm though and you'd get an image stabilizer which is lacking in both the Sigma as well as the Canon lens.
The Tamron SP 15-30mm f/2.8 Di VC USD G2 is a force to be reckoned with in its market segment. At optimal aperture settings, it is capable of delivering very sharp results across the zoom range. Given the extreme nature of the beast, some weaknesses at f/2.8 are to be expected. Namely, the image corners could be sharper at the extreme ends here. Lateral CAs are fairly well-controlled but it is advisable to apply some digital trickery to get reduce the issue nonetheless. Image distortions are typical with a heavy barrel distortion at the 15mm setting. Vignetting is clearly visible at fully open aperture but the amount is actually lower than in competing lenses in this respect.
Tamron tweaked the build quality in its G2 lenses. Gone is the old cheap plastic feel and there's a new sense of sturdiness thanks to higher quality materials now. The controls operate smoothly and nothing wobbles. While Tamron doesn't mention a sealing against dust, it is at least moisture-resistant. Tamron's USD AF is quite fast albeit the accuracy wasn't always spot on - maybe an issue with our specific sample. This is something that could be tuned via Tamron's optional "TAP-in" console though. A welcome improvement is the slightly higher (1/2 f-stop) efficiency of the optical image stabilizer.
Both the image and build quality are really fine but make sure that you can live with the size/weight. On the upside, it may help to strengthen your biceps and other than the reasonable pricing, this comes for free.
