Tamron AF 24-70mm f/2.8 SP Di USD VC (Canon EOS) - Full Format Review / Lens Test - Analysis |
Canon EOS (Full Format)
Page 2 of 3
At 24 mm the lens shows a heavy amount of barrel distortion (~3.8%), which flips over to a slight pincushion type (~0.8%) at 70mm. In the middle range distortion is marginal.
24mm |
35mm |
50mm |
70mm |
At 24mm f/2.8 the amount of vignetting is very pronounced at more that 2EV (f-stops) but can be decreased by stopping down. However, even stopped down to f/8 light falloff remains a bit on the high side and can still be seen in critical scenes. Things look similar albeit slight better at other focal lengths - very visible vignetting wide open but stopping down helps to decrease the amount considerably. Regarding its ultra-large front element we hoped that the lens performed a little better here.
The lens delivered very solid resolution figures in the MTF lab. At 24mm the center resolution is already superb at f/2.8. The border/corner quality is on a good level at large apertures and improves to very good border results from f/4 onward. The corners require f/8 to jump across this rating barrier. This pattern is also roughly valid for the 35mm and 50mm settings. At 70mm we are seeing a slight decrease in center performance at f/2.8. The contrast level is also slightly reduced here. However, the center is excellent from f/4 onward and the lens delivers very high quality results across the frame from f/5.6 to f/11. At f/11 there's a slight hint of diffraction (reduces the image quality) so you should avoid to choose an aperture beyond this setting if possible.
The Tamron lens has only a slight amount of field curvature throughout the zoom range which is certainly an advantage of the Canon EF 24-70mm f/2.8 USM L (I).
The centering quality of the tested sample was generally good from a lab perspective. We have experienced one outlier during the field session - see the church sample in the image sample section. This may have related to a VC effect.
Imatest Explanations
Chromatic aberrations (color shadows at harsh contrast transitions) are very well controlled and not relevant at all tested aperture settings and focal lengths. This is quite impressive.
Being a fast lens, it allows for good subject separation and thus the quality of out-of-focus blur is certainly of interest. We looked at bokeh with our standard test scene at 70mm focal length, which is closest to classic head to shoulder portrait lenses (~85mm).
The general quality of the background blur is quite smooth (see the left sample crop below). However, the foreground blur is more busy (to the right).
Thanks to 9 rounded aperture blades, background highlights retain their circular shape throughout the whole aperture range. However, the inner area of the highlight disc is rather nervous - possibly a side effect of the aspherical elements. The highlight discs deteriorate a bit towards the usual "cat's eye" towards the borders. This effect can be reduced by stopping down. The highlight discs (in the center) remain circular even at f/5.6 so the design of the rounded aperture blades is obvious here.
LoCAs (non-coinciding focal planes of the various colors) are a common issue with relatively fast glass - they are often noticeable in out-of-focus halos: magenta (red + blue) in front the focus point and green beyond. Surprisingly the Tamron is only marginally affected.
If you scroll through the images below you may notice a slight shift in focus when stopping down. This is a so-called "residual spherical aberration".
f/2.8 |
f/4.0 |
f/5.6 |
