Laowa 10mm f/2 Zero-D MFT - Review / Test Report - Sample Images & Verdict
MakeOLYMPUS IMAGING CORP.
ModelE-M5MarkII
ISO Speed200
Focal Length10.0mm
Aperture:f/5.6
Exposure1/1000s
ModelE-M5MarkII
ISO Speed320
Focal Length10.0mm
Aperture:f/2.0
Exposure1/60s
ModelE-M5MarkII
ISO Speed500
Focal Length10.0mm
Aperture:f/2.0
Exposure1/80s
ModelE-M5MarkII
ISO Speed1600
Focal Length10.0mm
Aperture:f/4.0
Exposure1/25s
ModelE-M5MarkII
ISO Speed500
Focal Length10.0mm
Aperture:f/2.0
Exposure1/60s
ModelE-M5MarkII
ISO Speed1250
Focal Length10.0mm
Aperture:f/2.0
Exposure1/60s
ModelE-M5MarkII
ISO Speed200
Focal Length10.0mm
Aperture:f/4.5
Exposure1/1250s
ModelE-M5MarkII
ISO Speed200
Focal Length10.0mm
Aperture:f/5.6
Exposure1/800s
ModelE-M5MarkII
ISO Speed200
Focal Length10.0mm
Aperture:f/5.6
Exposure1/125s
ModelE-M5MarkII
ISO Speed200
Focal Length10.0mm
Aperture:f/5.6
Exposure1/1250s
The Laowa 10mm f/2 Zero-D MFT is a fun lens that also has the capability of delivering some serious results. In terms of optical performance is shines with a very high resolution straight from f/2 and it's darn sharp at f/4. As the name implies, it is a fully distortion-corrected lens - which is a rare quality in mirrorless land. And this raises the question of why Olympus/Panasonic can't do the same here. The high corner quality can also be contributed to the fact that distortion correction isn't necessary at all. That being said, auto-correction DOES help when it comes to vignetting. The raw vignetting is on the extreme side at f/2 so unless you are after a keyhole effect you should keep it activated. Even so - some obvious vignetting remains at f/2. Lateral CAs are pretty low and nothing to worry about. Flare can be an issue in extreme lighting situations. If you are after sun stars - yes, the lens can give you these in qualifying scenes when stopping down and the quality is good. We haven't executed a formal analysis of the bokeh but as you can see in the sample image section, the out-of-focus blur is pretty smooth. This is a rather rare quality in an ultra-wide lens.
The Laowa 10mm f/2 Zero-D MFT is a tiny and super-lightweight lens. This doesn't mean that the build quality is suffering - on the contrary, it is actually very good. The lens body is made of metal and the focusing is smooth. There is no weather-sealing though. Unlike early Laowa offerings, the lens is fully coupled thus you can select the aperture on the camera rather than on the lens. EXIF data is also provided. However, you still have to live with manual focusing only. Given the ultra-wide nature of the lens, this shouldn't be a big deal for most users at least.
We quite enjoyed our time with this little marvel also because it highlights what's cool about the Micro-Four-Thirds system - a nice size factor combined with low weight. It may not be perfect in every optical aspect but if you are after a fast ultra-wide lens that doesn't go bonkers in terms of field-of-view, you should have a deeper look.
