Zeiss Distagon T* 25mm f/2 ZF.2 (FX) - Review / Test Report - Analysis
The Zeiss Distagon T* 25mm f/2 produces a moderate degree (~1.8%) of barrel distortion. This is about average for a prime lens in this class and also almost identical to the older Distagon T* 25mm f/2.8.
The vignetting characteristic seems to be a real weakness of Zeiss Z-series lenses when used on full format DSLRs. The Distagon shows a fairly extreme deterioration of more than 2EV at f/2 - this will be very visible in most scenes. The problem is still quite pronounced at f/2.8 (@ ~1.5EV) but it's not overly significant anymore from f/5.6 onwards.
The Zeiss lens produced very high resolution figures in the MTF lab. The center quality is nothing short of stunning with extremely high resolution combined with snappy contrast straight from f/2.
The border quality is a bit weaker with very good results and the corners are softer still. Stopping down to f/2.8 has no major effect but there's a more substantial boost at f/4. The peak performance is reached around f/5.6 with a very sharp image quality across the image frame. The quality level is kept at f/8 whereas diffraction reduces the potential from f/11 onward.
Zeiss claims to have substantially reduced lateral CAs (color shadows at harsh contrast transitions) on this lens and they are indeed on a fairly low level of around 0.5px on the average at the image borders. This is hardly field-relevant.
